location-policy
Creates a Location
policy and enters its configuration mode. Use this command to configure a
policy that provides the ExtremeLocation server hostname, and the
ExtremeLocation Tenant‘s API key needed to authenticate and authorize with
the server. Apply this Location policy on the WiNG devices (site
controller, virtual controllers, and standalone APs). When applied, these
devices push/export site hierarchy to the ExtremeLocation server. The site
hierarchy includes site details along with details of APs deployed within
the site.
Once created
and configured, apply this Location policy on the
WiNG controller‘s
self, to enable Tenant site hierarchy reporting by the controller to the
- Access Points —
AP510, AP505
- Wireless Controllers
— RFS4000
- Service Platforms — NX5500,
NX7500, NX9500, NX9600
Syntax
location-policy <LOCATION-POLICY-NAME>
Parameters
location-policy <LOCATION-POLICY-NAME> |
Specify the Location Policy name. If a policy with the
specified name does not exist, it is created. |
nx9500-6C8809(config)#eloc-policy testLocPolicy
nx9500-6C8809(config-eloc-policy-testLocPolicy)#?
Eloc Policy Mode commands:
enable Enable this eloc policy
location-key API key used for location service
no Negate a command or set its defaults
server-host ExtremeLocation server configuration
clrscr Clears the display screen
commit Commit all changes made in this session
end End current mode and change to EXEC mode
exit End current mode and down to previous mode
help Description of the interactive help system
revert Revert changes
service Service Commands
show Show running system information
write Write running configuration to memory or terminal
Related Commands
no |
Removes an existing Location policy from the
system |
